本指南有最近更改,您可查看未经巡查的最新版本。
简介
The speaker cover, located above the keyboard, can be removed by following these simple steps.
你所需要的
Locate the two sliding locks indicated in the photo.
Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
Slide the left lock (labeled "2") to the left and hold it in place.
Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
即将完成!
结论
