跳转到主内容
Toshiba Satellite A205-S4577 Speaker Cover Replacement
你所需要的
  1. Toshiba Satellite A205-S4577 Speaker Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the two sliding locks indicated in the photo.
    • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
    • Slide the left lock (labeled "2") to the left and hold it in place.
  2. Toshiba Satellite A205-S4577 Speaker Cover Replacement: 步骤 2 中的图像 1,1
    • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
  3. Toshiba Satellite A205-S4577 Speaker Cover Replacement, Speaker Cover: 步骤 3 中的图像 1,3 Toshiba Satellite A205-S4577 Speaker Cover Replacement, Speaker Cover: 步骤 3 中的图像 2,3 Toshiba Satellite A205-S4577 Speaker Cover Replacement, Speaker Cover: 步骤 3 中的图像 3,3
    • Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
  4. Toshiba Satellite A205-S4577 Speaker Cover Replacement: 步骤 4 中的图像 1,1
    • With your hands, grasp the speaker cover on the edge nearest to the screen.
    • Pry the speaker cover upward.
  5. Toshiba Satellite A205-S4577 Speaker Cover Replacement: 步骤 5 中的图像 1,1
    • Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
结论
Daniel Johnson
于04/07/13注册
108 声望
创作了4篇指南
团队
Cal Poly, Team 17-6, Regan Spring 2013 Cal Poly, Team 17-6, Regan Spring 2013 的会员
CPSU-REGAN-S13S17G6
5 名成员
创作了33篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,297
