跳转到主内容
Toshiba Satellite A205-S4577 RAM Replacement
你所需要的
  1. Toshiba Satellite A205-S4577 RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Identify the rectangular plastic RAM cover located in the bottom part of your laptop.
    • Remove the 4mm flat-head screws on the RAM cover.
    • Use a plastic opening tool to pry the RAM cover upward.
  2. Toshiba Satellite A205-S4577 RAM Replacement: 步骤 2 中的图像 1,1
    • Remove the RAM cover.
  3. Toshiba Satellite A205-S4577 RAM Replacement: 步骤 3 中的图像 1,1
    • Press the two tabs on the side of the PC2-5300 2 GB RAM Chip to unlatch it.
    • To remove the PC2-5300 2 GB RAM Chip, pull it out at a slightly upward angle.
  4. Toshiba Satellite A205-S4577 RAM Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite A205-S4577 RAM Replacement: 步骤 4 中的图像 2,2
    • To replace the ram, insert the new PC2-5300 1 GB RAM Chip you have gathered back into the laptop.
    • Make sure the notch in the middle of the stick is lined up correctly and push firmly into place.
    • Once pushed firmly into place, firmly push down and latch the RAM sticks to the laptop. Repeat process for additional RAM sticks.
  5. Toshiba Satellite A205-S4577 RAM Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite A205-S4577 RAM Replacement: 步骤 5 中的图像 2,2
    • To replace the ram, insert the new RAM sticks you have back into the computer.
    • Once pushed firmly into place, firmly push down and latch the RAM sticks to the computer. Repeat process for additional RAM sticks.
  6. Toshiba Satellite A205-S4577 RAM Replacement: 步骤 6 中的图像 1,1
    • Screw the back plate of the RAM back onto the device.
终点
Daniel Johnson
于04/07/13注册
108 声望
创作了4篇指南
团队
Cal Poly, Team 17-6, Regan Spring 2013 Cal Poly, Team 17-6, Regan Spring 2013 的会员
CPSU-REGAN-S13S17G6
5 名成员
创作了33篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,382
