跳转到主内容
Toshiba Satellite A205-S4577 Optical Drive Replacement
你所需要的
  1. Toshiba Satellite A205-S4577 Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the two sliding locks indicated in the photo.
    • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
    • Slide the left lock (labeled "2") to the left and hold it in place.
  2. Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
  3. Toshiba Satellite A205-S4577 Optical Drive Replacement, Speaker Cover: 步骤 3 中的图像 1,3 Toshiba Satellite A205-S4577 Optical Drive Replacement, Speaker Cover: 步骤 3 中的图像 2,3 Toshiba Satellite A205-S4577 Optical Drive Replacement, Speaker Cover: 步骤 3 中的图像 3,3
    • Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
  4. Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 4 中的图像 1,1
    • With your hands, grasp the speaker cover on the edge nearest to the screen.
    • Pry the speaker cover upward.
  5. Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
  6. Toshiba Satellite A205-S4577 Optical Drive Replacement, Keyboard: 步骤 6 中的图像 1,1
    • Remove the two 4mm flat-head screws indicated in the photo.
  7. Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 7 中的图像 1,1
    • Slightly lift and ease the keyboard forward, toward the screen, until the tabs clear the case.
    • When all the tabs are free, slowly lift the bottom of the keyboard while keeping the top of the keyboard angled down. Continue to carefully rotate the keyboard over until you can access the ribbon cable that is still connecting it to the computer.
  8. Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 8 中的图像 1,1
    • The Ribbon Cable must be disconnected here to release the keyboard.
    • Using a plastic splunger or the tip of your screwdriver gently push upward on the two black tabs securing the connection.
    • When the black plastic bar running across the cable is unseated you can slowly and carefully pull the ribbon cable free.
    • You can now lift and remove the keyboard.
  9. Toshiba Satellite A205-S4577 Optical Drive Replacement, Monitor: 步骤 9 中的图像 1,3 Toshiba Satellite A205-S4577 Optical Drive Replacement, Monitor: 步骤 9 中的图像 2,3 Toshiba Satellite A205-S4577 Optical Drive Replacement, Monitor: 步骤 9 中的图像 3,3
    • Locate the gray wire on the right.
    • Detach the white end by gently pulling each socket away from the other.
  10. Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 10 中的图像 1,2 Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 10 中的图像 2,2
    • On the left, locate the black and white wires with gold tips on the end.
    • Pull up on the wires to detach them.
  11. Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 11 中的图像 1,3 Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 11 中的图像 2,3 Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 11 中的图像 3,3
    • Locate the thick tan cord on the left.
    • Slide the tan cord as shown to detach it.
  12. Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 12 中的图像 1,2 Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 12 中的图像 2,2
    • On the right, locate the thick black wire with the white rectangular end.
    • Pull up on it to detach it.
  13. Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 13 中的图像 1,3 Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 13 中的图像 2,3 Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 13 中的图像 3,3
    • Remove the four 8mm button-head screws that are located in the top right (2) and top left corners (2) of the front cover. Use a Phillips 00 Screwdriver.
  14. Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 14 中的图像 1,1
    • Once all the wires are detached and screws are removed, pull up on the monitor to remove it.
  15. Toshiba Satellite A205-S4577 Optical Drive Replacement, Front Cover: 步骤 15 中的图像 1,1
    • Locate the screws that are shown in the image.
    • Remove the fourteen 6mm button-head screws with a Phillips 00 Screwdriver.
  16. Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 16 中的图像 1,2 Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 16 中的图像 2,2
    • Lift up on the front cover to remove it.
  17. Toshiba Satellite A205-S4577 Optical Drive Replacement, Optical Drive: 步骤 17 中的图像 1,1
    • Locate the 4mm flat-head screw. Remove it using the Phillips 00 Screwdriver.
  18. Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 18 中的图像 1,1
    • Turn the computer over.
    • Locate the optical drive on the right.
  19. Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 19 中的图像 1,3 Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 19 中的图像 2,3 Toshiba Satellite A205-S4577 Optical Drive Replacement: 步骤 19 中的图像 3,3
    • Using two fingers, slide the optical drive toward the edge of the computer.
    • Continue to slide the optical drive until it can be removed from the computer.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 17-6, Regan Spring 2013 Cal Poly, Team 17-6, Regan Spring 2013 的会员
CPSU-REGAN-S13S17G6
5 名成员
创作了33篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 858
