跳转到主内容
Toshiba Satellite A205-S4577 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite A205-S4577 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Locate the hard drive cover on the bottom, left-hand corner of your laptop.
    • Using a Phillips #00 screwdriver, remove both 4mm screws.
  2. Toshiba Satellite A205-S4577 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Lift the cover to reveal the old hard drive.
    • Carefully detach the hard drive from the SATA/Power connector.
  3. Toshiba Satellite A205-S4577 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • After removing the old hard drive, place the new hard drive into the bay, and firmly reattach it to the SATA/Power connector.
结论
Daniel Johnson
于04/07/13注册
108 声望
创作了4篇指南
团队
Cal Poly, Team 17-6, Regan Spring 2013 Cal Poly, Team 17-6, Regan Spring 2013 的会员
CPSU-REGAN-S13S17G6
5 名成员
创作了33篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 13
总计 2,393
