当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Make sure your computer is turned off and the computer is not plugged in.
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
Use the plastic opening tool to pop off tabs along the length of this panel.
This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
Disconnect wire attaching LCD to motherboard
Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers
Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
Remove the seventeen 4.5mm phillips screws on the bottom of the laptop.
Using the pry tool separate the two halves of the laptop base.
Use caution when separating the laptop halves as they are still connected by two ribbon cables.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
