跳转到主内容
简介
This guide will help you replace Toshiba Satellite A105-S4284 RAM. RAM allows memory to be accessed directly in a random order. You might need to replace a RAM if your computer shuts down abruptly, your computer performance is low quality, or the computer fails to install new programs.
  1. Make sure your computer is turned off and the computer is not plugged in. Turn your laptop upside down, and slide the right release tab outward.
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver. You will not be able to remove the screw from the panel as it is designed to stay in the panel.
    • Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
    • You will not be able to remove the screw from the panel as it is designed to stay in the panel.
  3. With your fingers, carefully remove the middle panel by lifting the edge with the indent. With your fingers, carefully remove the middle panel by lifting the edge with the indent.
    • With your fingers, carefully remove the middle panel by lifting the edge with the indent.
  4. Using your fingers, release the tabs on both ends of the RAM. Pull the RAM out. The other RAM is released in the same manner.
    • Using your fingers, release the tabs on both ends of the RAM.
    • Pull the RAM out.
    • The other RAM is released in the same manner.
结论
另外一个人完成了本指南。
pfedigan
于2013年04月12日注册
11 信誉积分
创作了4篇指南
团队
Cal Poly, Team 2-23, Maness Spring 2013 Cal Poly, Team 2-23, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G23
4 名成员
创作了5篇指南
how to remove a bios passcode off of a Toshiba Satellite a105 s4374 laptop
simeon cole - 回复
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 7
过去的30天: 19
总计 1,473
