跳转到主内容
Toshiba Satellite A105-S4284 Keyboard Replacement
你所需要的
  1. Toshiba Satellite A105-S4284 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite A105-S4284 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
  3. Toshiba Satellite A105-S4284 Keyboard Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite A105-S4284 Keyboard Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite A105-S4284 Keyboard Replacement: 步骤 3 中的图像 3,3
    • Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
    • Use the plastic opening tool to pop off tabs along the length of this panel.
    • This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
  4. Toshiba Satellite A105-S4284 Keyboard Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite A105-S4284 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
  5. Toshiba Satellite A105-S4284 Keyboard Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite A105-S4284 Keyboard Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite A105-S4284 Keyboard Replacement: 步骤 5 中的图像 3,3
    • Lift the keyboard gently from the side closest the screen.
    • Pull out the ribbon connecting the keyboard to the laptop.
结论
另外一个人完成了本指南。
pfedigan
于04/12/13注册
11 声望
创作了4篇指南
团队
Cal Poly, Team 2-23, Maness Spring 2013 Cal Poly, Team 2-23, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G23
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 1,455
