跳转到主内容
简介
If your CDs or DVDs are not running correctly or at all on your computer, then it is either due to the disc drive being dirty, loose parts and/or broken. This guide will show the user how to safely remove the disc drive.
  1. Make sure your computer is turned off and the computer is not plugged in. Turn your laptop upside down, and slide the right release tab outward.
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver. You will not be able to remove the screw from the panel as it is designed to stay in the panel.
    • Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
    • You will not be able to remove the screw from the panel as it is designed to stay in the panel.
  3. With your fingers, carefully remove the middle panel by lifting the edge with the indent. With your fingers, carefully remove the middle panel by lifting the edge with the indent.
    • With your fingers, carefully remove the middle panel by lifting the edge with the indent.
  4. Remove the 4.0 mm screw above the small metal tab with a Phillips 00 screwdriver. Remove the 4.0 mm screw above the small metal tab with a Phillips 00 screwdriver.
    • Remove the 4.0 mm screw above the small metal tab with a Phillips 00 screwdriver.
  5. Push down on the metal tab under the cover with the plastic opening tool and push the disc drive partially out. Grab the drive and pull it out of the laptop.
    • Push down on the metal tab under the cover with the plastic opening tool and push the disc drive partially out.
    • Grab the drive and pull it out of the laptop.
结论
pfedigan
于2013年04月12日注册
11 信誉积分
创作了4篇指南
团队
Cal Poly, Team 2-23, Maness Spring 2013 Cal Poly, Team 2-23, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G23
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 596
