跳转到主内容
Toshiba Satellite A105-S4284 Casing Replacement
你所需要的
  1. Toshiba Satellite A105-S4284 Casing Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
  2. Toshiba Satellite A105-S4284 Casing Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite A105-S4284 Casing Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite A105-S4284 Casing Replacement: 步骤 2 中的图像 3,3
    • Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
    • Use the plastic opening tool to pop off tabs along the length of this panel.
    • This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
  3. Toshiba Satellite A105-S4284 Casing Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite A105-S4284 Casing Replacement: 步骤 3 中的图像 2,2
    • Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
  4. Toshiba Satellite A105-S4284 Casing Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite A105-S4284 Casing Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite A105-S4284 Casing Replacement: 步骤 4 中的图像 3,3
    • Lift the keyboard gently from the side closest the screen.
    • Pull out the ribbon connecting the keyboard to the laptop.
  5. Toshiba Satellite A105-S4284 Casing Replacement, Casing: 步骤 5 中的图像 1,3 Toshiba Satellite A105-S4284 Casing Replacement, Casing: 步骤 5 中的图像 2,3 Toshiba Satellite A105-S4284 Casing Replacement, Casing: 步骤 5 中的图像 3,3
    • Disconnect wire attaching LCD to motherboard
    • Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers
    • Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
  6. Toshiba Satellite A105-S4284 Casing Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite A105-S4284 Casing Replacement: 步骤 6 中的图像 2,2
    • Remove the seventeen 4.5mm phillips screws on the bottom of the laptop.
    • Using the pry tool separate the two halves of the laptop base.
    • Use caution when separating the laptop halves as they are still connected by two ribbon cables.
  7. Toshiba Satellite A105-S4284 Casing Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite A105-S4284 Casing Replacement: 步骤 7 中的图像 2,2
    • Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard.
结论
2等其他人完成本指南。
Josh
于03/12/14注册
685 声望
创作了5篇指南
团队
UMass Dartmouth, Team 1-6, Cichon Spring 2014 UMass Dartmouth, Team 1-6, Cichon Spring 2014 的会员
UMASSD-CICHON-S14S1G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 891
