简介
The hard drive is the storage space of your computer, containing your music, photos, programs, and documents. It also houses your operating system. Save all the files you want to keep on an external device before installing a new hard drive, as replacing the hard drive basically gives you a new computer.
配件
无需配件。
  1. Make sure your computer is turned off and the computer is not plugged in. Turn your laptop upside down, and slide the right release tab outward.
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Turn the laptop around 180 degrees. Unscrew the 4 mm screw with the Philips #1 screwdriver. Lift and remove the hard drive cover.
    • Turn the laptop around 180 degrees.
    • Unscrew the 4 mm screw with the Philips #1 screwdriver.
    • Lift and remove the hard drive cover.
  4. Pull on the rubber tab to slide the hard drive to the left. Pick up the near side of the hard drive and pull it out the back. Pick up the near side of the hard drive and pull it out the back.
    • Pull on the rubber tab to slide the hard drive to the left.
    • Pick up the near side of the hard drive and pull it out the back.
结论
另外一个人完成了本指南。
pfedigan
于2013年04月12日注册
11 信誉积分
创作了4篇指南
团队
Cal Poly, Team 2-23, Maness Spring 2013 Cal Poly, Team 2-23, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G23
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 15
总计 1,896
