简介
After diagnosing your Toshiba Satellite A105-S4074, should you conclude that the optical disk drive has failed and will need to be replaced, these easy to follow instructions will guide you through the process.
你所需要的
Turn the laptop around with the battery slot facing away from you.
Remove the 5.0 mm screw that is holding the optical disk drive internally in place using the Phillips #1 screwdriver.
To reassemble your device after replacing the DVD SuperMulti drive, follow these instructions in reverse order.
另外一个人完成了本指南。
