跳转到主内容
Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement
你所需要的
  1. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Battery: 步骤 1 中的图像 2,2
    • To prevent electrical shock, make sure the computer is turned off; and disconnect the power adapter from the computer and electrical outlet prior to beginning any repairs on this device.
    • Turn the laptop upside down with the battery facing you.
  2. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: 步骤 2 中的图像 3,3
    • Slide both the left and right battery release tabs outwards away from center of the laptop.
    • Right release tab will remain locked in place.
    • While still holding the left release tab, slide the battery towards you using your right hand.
    • Fully remove the battery from the laptop.
  3. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Optical Disk Drive (DVD/CD-ROM): 步骤 3 中的图像 1,2 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Optical Disk Drive (DVD/CD-ROM): 步骤 3 中的图像 2,2
    • Turn the laptop around with the battery slot facing away from you.
    • Remove the 5.0 mm screw that is holding the optical disk drive internally in place using the Phillips #1 screwdriver.
  4. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: 步骤 4 中的图像 3,3
    • Turn the laptop back over (cover-side up) with the optical disk drive on the right side.
    • With the plastic opening tool, pry the drive out from the top.
    • Using the opening tool, pull the drive out of the drive bay.
结论
To reassemble your device after replacing the DVD SuperMulti drive, follow these instructions in reverse order.
另外一个人完成了本指南。
Ryan Bortnick
于03/20/17注册
722 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 15
总计 570
