跳转到主内容
Toshiba Satellite A105-S4074 Battery Replacement
你所需要的
  1. Toshiba Satellite A105-S4074 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite A105-S4074 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • To prevent electrical shock, make sure the computer is turned off; and disconnect the power adapter from the computer and electrical outlet prior to beginning any repairs on this device.
    • Turn the laptop upside down with the battery facing you.
  2. Toshiba Satellite A105-S4074 Battery Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite A105-S4074 Battery Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite A105-S4074 Battery Replacement: 步骤 2 中的图像 3,3
    • Slide both the left and right battery release tabs outwards away from center of the laptop.
    • Right release tab will remain locked in place.
    • While still holding the left release tab, slide the battery towards you using your right hand.
    • Fully remove the battery from the laptop.
结论
To reassemble your device after inserting the replacement battery, follow these instructions in reverse order.
3等其他人完成本指南。
Ryan Bortnick
于03/20/17注册
722 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 367
