简介
This guide is relatively straight-forward as there are only few screws holding the speaker in place. The most difficult parts of this guide are the prerequisites; removing the keyboard, as well as separating the display from the motherboard.
你所需要的
Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
Open the laptop so the display screen is bent fully back with the display facing upward, parallel to the surface you are working on.
Wedge the Phillips 00 screwdriver above the F1 key, and separate the top piece of plastic from the body of the laptop. Don't worry about breaking it! You will need to forcefully wedge the screwdriver under the plastic, simultaneously pushing upward and forward.
Once that section has popped up, work on pulling the rest of the plastic piece up and out, alternating from left to right.
步骤 6 Display
注意:步骤 6-7 源自标记为进行中的 指南。
Turn the laptop over, so that you are now looking at the bottom of the laptop.
Using the Phillips #1 screwdriver remove the fourteen 6mm screws.
Using the Phillips #1 screwdriver remove the three 4mm screws.
On the top half of the disassembled laptop (the part that is connected to the display) use the #1 Phillips Screw Driver to remove the four 5mm screws holding the speakers in place.
4等其他人完成本指南。
