跳转到主内容
Toshiba Satellite A105-S4011 RAM Replacement
你所需要的
  1. Toshiba Satellite A105-S4011 RAM Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite A105-S4011 RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 RAM Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite A105-S4011 RAM Replacement: 步骤 2 中的图像 2,2
    • Hold the release switch and pull out the battery towards you.
  3. Toshiba Satellite A105-S4011 RAM Replacement, RAM: 步骤 3 中的图像 1,1
    • Locate the screw that is holding the back cover in place and, unscrew it using the #1 Phillips Screwdriver.
    • This screw cannot be taken out, it is a "captive" screw.
  4. Toshiba Satellite A105-S4011 RAM Replacement: 步骤 4 中的图像 1,1
    • Using a plastic opening tool, pop off the back cover. Your going to insert the tool into the small slit located on the back cover piece.
    • Be careful when prying the back cover off because you may damage the cover or crack the plastic.
  5. Toshiba Satellite A105-S4011 RAM Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite A105-S4011 RAM Replacement: 步骤 5 中的图像 2,2
    • Locate the RAM (green module pictured here), and the two prongs on each side of the module. Press the two prongs outwardly, and pull out the RAM module.
    • Grounding yourself may be a good idea before actually touching the RAM module. This entails touching a conductive metal in order to remove any excess static energy in your body.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 4-14, Maness Spring 2013 Cal Poly, Team 4-14, Maness Spring 2013 的会员
CPSU-MANESS-S13S4G14
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 30
总计 1,321
