跳转到主内容
简介
This guide will show you how to remove the current Hard Drive and how to replace it. Accessing the Hard Drive in this computer is straightforward and only requires minimal dis-assembly with a screwdriver. Make sure your new hard disk is compatible with your device before attempting to install it because it may not fit, may have different wiring, etc.
配件
没有特定配件。
  1. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite A105-S4011 Hard Disk Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: 步骤 2 中的图像 2,2
    • Hold the release switch and pull out the battery towards you.
  3. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement, Hard Disk Drive: 步骤 3 中的图像 1,1
    • Turn the laptop so the battery-side of the laptop is farthest from you. Locate the captive screw pictured here and loosen the screw using the #1 Phillips screwdriver.
    • You may want to ground yourself before attempting to touch any components. This means touching a conductive metal to eliminate any static buildup in your body, which can damage computer components.
    • Make sure your new hard disk is compatible with your device before attempting to install it because it may not fit, may have different wiring, etc.
  4. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: 步骤 4 中的图像 1,1
    • Once the screw is completely removed, pull back the plastic cover carefully.
    • If you are having trouble removing the cover, a plastic removal tool may be used.
  5. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the hard disk by gently applying pressure with your thumb while sliding the hard disk to the left.
    • If you do not ground yourself, you run the risk of damaging your hard disk.
结论
4等其他人完成本指南。
Connor Russell
于2013年04月18日注册
49 声望
撰写一个指南
团队
Cal Poly, Team 4-14, Maness Spring 2013 Cal Poly, Team 4-14, Maness Spring 2013 的会员
CPSU-MANESS-S13S4G14
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,473
