跳转到主内容
Toshiba Satellite A105-S4011 Battery Replacement
  1. Toshiba Satellite A105-S4011 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite A105-S4011 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 Battery Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite A105-S4011 Battery Replacement: 步骤 2 中的图像 2,2
    • Hold the release switch and pull out the battery towards you.
结论
6等其他人完成本指南。
团队
Cal Poly, Team 4-14, Maness Spring 2013 Cal Poly, Team 4-14, Maness Spring 2013 的会员
CPSU-MANESS-S13S4G14
4 名成员
创作了14篇指南
2条评论
I have Toshiba E45t-A4300 soft touch screen. The battery is spoilt. The battery compartment is not accessible. How do I remove it and replace it with a new one,?
Benjamin Osei - 回复
The part number is PSUB2U-00K00P
Benjamin Osei - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 1,275
