跳转到主内容
Toshiba Satellite 2435-S255 Battery Replacement
  1. Toshiba Satellite 2435-S255 Battery Replacement, Removing the Latch: 步骤 1 中的图像 1,2 Toshiba Satellite 2435-S255 Battery Replacement, Removing the Latch: 步骤 1 中的图像 2,2
    • The latch on this is tricky. Fortunately, it’s the only thing you have to deal with.
    • First, slide the latch until you hit resistance. At this point, you have two options.
    • You can either keep pushing the latch until the battery pops out. . .
    • or you can start prying the battery out while pushing the latch (as shown in the second picture above).
  2. Toshiba Satellite 2435-S255 Battery Replacement, Remove the Battery: 步骤 2 中的图像 1,1
    • Just lift the battery up and out, making sure to lift from the end near the latch.
    • Now the battery is out! To put it back, just insert it back in from the same angle you took it out on.
结论
团队
UMass Dartmouth, Team 1-5, Shastany Fall 2014 UMass Dartmouth, Team 1-5, Shastany Fall 2014 的会员
UMASSD-SHASTANY-F14S1G5
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 247
