当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Pull the battery casing gently out toward yourself, until you hear a clicking sound.
The battery should pull out to about 2 inches.
Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
The keyboard is still connected to the laptop by a ribbon. Place the keyboard gently on top of the trackpad, keys side down.
Using a Phillips Screwdriver, unscrew and remove the one F4 screw closest to the center of the laptop.
This screw is underneath the battery casing, located on the bottom of the laptop directly under the trackpad.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
