当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Pull the battery casing gently out toward yourself, until you hear a clicking sound.
The battery should pull out to about 2 inches.
Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive.
The hard drive is located next to the CD drive.
Pull the white plastic out toward you. This should remove the hard drive tray from the laptop.
This laptop does not have a hard drive, so the tray is empty. On your computer, the hard drive should be in the tray.
Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
The keyboard is still connected to the laptop by a ribbon. Place the keyboard gently on top of the trackpad, keys side down.
Using a Phillips Screwdriver, unscrew and remove the one F4 screw closest to the center of the laptop.
This screw is underneath the battery casing, located on the bottom of the laptop directly under the trackpad.
Using a Phillips screwdriver, unscrew and remove two screws labeled B5.5, located to the right of where the metal piece was.
These screws are silver, where all the other screws have been black.
Using a Phillips screwdriver, unscrew and remove two black screws from the back side of the laptop.
These screws are not labeled.
Using your fingers, pinch the black modem piece, lift and slide the modem up and move it aside.
The modem is connected to a red and black wire.
Lift open the screen of the laptop and, using your fingers and the guides on the side of the laptop, push up on the top plastic covering of the laptop, moving from one side of the laptop to the other.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
