跳转到主内容
Toshiba Satellite 1805-S177 Keyboard Replacement
你所需要的
  1. Toshiba Satellite 1805-S177 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Toshiba Satellite 1805-S177 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
  2. Toshiba Satellite 1805-S177 Keyboard Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite 1805-S177 Keyboard Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite 1805-S177 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6.
  3. Toshiba Satellite 1805-S177 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
    • The keyboard is still connected to the laptop by a ribbon. Place the keyboard gently on top of the trackpad, keys side down.
  4. Toshiba Satellite 1805-S177 Keyboard Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite 1805-S177 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Slide the white ribbon connector up and lift the ribbon out of it.
结论
Hannah
于06/24/10注册
227 声望
创作了7篇指南
团队
Cal Poly, Team 3-5, Johann Summer 2010 Cal Poly, Team 3-5, Johann Summer 2010 的会员
CPSU-JOHANN-R10S3G5
4 名成员
创作了24篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,660
