跳转到主内容
Toshiba Satellite 1805-S177 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite 1805-S177 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 Toshiba Satellite 1805-S177 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive.
    • The hard drive is located next to the CD drive.
  2. Toshiba Satellite 1805-S177 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Placing your finger on the raised grip, push up on the hard drive cover. This will remove the hard drive cover from the laptop.
  3. Toshiba Satellite 1805-S177 Hard Drive Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite 1805-S177 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips screwdriver, unscrew and remove the screw surrounded by the white plastic.
  4. Toshiba Satellite 1805-S177 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Pull the white plastic out toward you. This should remove the hard drive tray from the laptop.
    • This laptop does not have a hard drive, so the tray is empty. On your computer, the hard drive should be in the tray.
结论
Hannah
于06/24/10注册
227 声望
创作了7篇指南
团队
Cal Poly, Team 3-5, Johann Summer 2010 Cal Poly, Team 3-5, Johann Summer 2010 的会员
CPSU-JOHANN-R10S3G5
4 名成员
创作了24篇指南
一条评论
How can I run a cd if I can't remember my hdd password on my toshiba l645 computer
Vera Hess - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 4,147
