跳转到主内容
Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement
你所需要的
  1. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Battery: 步骤 1 中的图像 1,1
    • The battery is located on the front right corner of the laptop.
  2. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 步骤 2 中的图像 1,1
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Pull the battery out towards the side.
  4. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 步骤 4 中的图像 2,2
    • Lift the battery straight up, out of the computer.
  5. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: 步骤 5 中的图像 1,3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: 步骤 5 中的图像 2,3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: 步骤 5 中的图像 3,3
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  6. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 步骤 6 中的图像 2,2
    • Unscrew the two screws near the top of the keyboard.
  7. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 步骤 7 中的图像 2,2
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  8. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 步骤 8 中的图像 1,3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 步骤 8 中的图像 2,3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 步骤 8 中的图像 3,3
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
  9. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Power Button Circuit Board: 步骤 9 中的图像 1,2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Power Button Circuit Board: 步骤 9 中的图像 2,2
    • Unscrew the screws on either side of the power button circuit board.
  10. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 步骤 10 中的图像 1,2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 步骤 10 中的图像 2,2
    • Pull upward on the small white ribbon cable to detach from circuit board.
结论
Kiril Lange
于09/22/14注册
943 声望
创作了9篇指南
团队
USF Tampa, Team 3-2, Brown Fall 2014 USF Tampa, Team 3-2, Brown Fall 2014 的会员
USFT-BROWN-F14S3G2
3 名成员
创作了27篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 24
总计 1,471
