跳转到主内容
Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement
你所需要的
  1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Battery: 步骤 1 中的图像 1,1
    • The battery is located on the front right corner of the laptop.
  2. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 2 中的图像 1,1
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 3 中的图像 2,2
    • Pull the battery out towards the side.
  4. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 4 中的图像 2,2
    • Lift the battery straight up, out of the computer.
  5. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Lower Case: 步骤 5 中的图像 1,1
    • Unscrew all of the visible screws on the bottom of the laptop.
    • The screws circled are not necessary to remove.
    • Keeping track of which hole each screw goes in will speed up reassembly.
  6. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 6 中的图像 1,1
    • Unscrew the screws located beneath the battery.
  7. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: 步骤 7 中的图像 1,3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: 步骤 7 中的图像 2,3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: 步骤 7 中的图像 3,3
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  8. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 8 中的图像 2,2
    • Unscrew the two screws near the top of the keyboard.
  9. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 9 中的图像 2,2
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  10. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 10 中的图像 1,3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 10 中的图像 2,3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 10 中的图像 3,3
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
  11. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Power Button Circuit Board: 步骤 11 中的图像 1,2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Power Button Circuit Board: 步骤 11 中的图像 2,2
    • Unscrew the screws on either side of the power button circuit board.
  12. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 12 中的图像 1,2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 12 中的图像 2,2
    • Pull upward on the small white ribbon cable to detach from circuit board.
  13. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Optical Drive: 步骤 13 中的图像 1,1
    • Unscrew the screw located on the left side of the optical drive near the heat sink cover in the middle of the laptop.
  14. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 14 中的图像 1,3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 14 中的图像 2,3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 14 中的图像 3,3
    • Using spudger, push the optical drive out to the right.
  15. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Upper Case: 步骤 15 中的图像 1,2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Upper Case: 步骤 15 中的图像 2,2
    • Disconnect both speaker connectors located near the center of the laptop.
  16. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 16 中的图像 1,2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 16 中的图像 2,2
    • Unscrew all visible screws on the heat sink shield.
  17. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 17 中的图像 1,2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 17 中的图像 2,2
    • Disconnect the monitor connector.
  18. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 18 中的图像 1,3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 18 中的图像 2,3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 18 中的图像 3,3
    • Starting from the front right corner pry apart the black bottom from the gray top.
  19. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 19 中的图像 1,2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 19 中的图像 2,2
    • Set aside the top half.
  20. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, CPU Fan and Heatsink: 步骤 20 中的图像 1,2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, CPU Fan and Heatsink: 步骤 20 中的图像 2,2
    • Unscrew the remaining screws on the heatsink and fan brackets.
  21. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 21 中的图像 1,3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 21 中的图像 2,3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 21 中的图像 3,3
    • Disconnect the fan power connector.
    • Remove the heatsink and fan.
    • Check the heatsink fins and fan for any dust build-up. If any is found use compressed air to clean.
  22. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 步骤 22 中的图像 1,1
    • Clean the old thermal paste off the CPU and heatsink.
    • Use a q tip to remove the majority of the thermal paste.
    • Use an isopropyl alcohol soaked q tip to further clean remaining thermal paste.
    • Dry and clean both surfaces with another q-tip.
    • Once completely clean, apply a rice grain sized amount of new thermal paste to the CPU and reattach the heatsink and fan.
结论
另外一个人完成了本指南。
Kiril Lange
于09/22/14注册
943 声望
创作了9篇指南
团队
USF Tampa, Team 3-2, Brown Fall 2014 USF Tampa, Team 3-2, Brown Fall 2014 的会员
USFT-BROWN-F14S3G2
3 名成员
创作了27篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 15
总计 890
