跳转到主内容
Toshiba SD-K740 Motherboard Replacement
你所需要的
  1. Toshiba SD-K740 Motherboard Replacement, Top Panel: 步骤 1 中的图像 1,1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Motherboard Replacement: 步骤 2 中的图像 1,2 Toshiba SD-K740 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Motherboard Replacement, Front Panel: 步骤 4 中的图像 1,1
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Motherboard Replacement: 步骤 6 中的图像 1,2 Toshiba SD-K740 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Grasp the front panel and pull forward to your right to remove it.
  7. Toshiba SD-K740 Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,1
    • Remove the black tie holding the two rear ribbon cables together by untwisting it.
  8. Toshiba SD-K740 Motherboard Replacement: 步骤 8 中的图像 1,2 Toshiba SD-K740 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove the first of two multipin cables connected to the Left-Side Motherboard (Green) by pulling vertically.
  9. Toshiba SD-K740 Motherboard Replacement: 步骤 9 中的图像 1,2 Toshiba SD-K740 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Remove the second of two multipin cables connected to the Left-Side Motherboard (Green) by pulling vertically.
  10. Toshiba SD-K740 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Pull the two cables to the right to disentangle from the disc drive.
    • Do not tug, pull, or force the cable. It should slide out with minimal force.
  11. Toshiba SD-K740 Motherboard Replacement: 步骤 11 中的图像 1,2 Toshiba SD-K740 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Remove the first of three ribbon cables on the left hand side of the disc drive by pulling vertically.
  12. Toshiba SD-K740 Motherboard Replacement: 步骤 12 中的图像 1,2 Toshiba SD-K740 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Remove the second of three ribbon cables on the left hand side of the disc drive by pulling vertically.
  13. Toshiba SD-K740 Motherboard Replacement: 步骤 13 中的图像 1,2 Toshiba SD-K740 Motherboard Replacement: 步骤 13 中的图像 2,2
    • Remove the third of three ribbon cables on the left hand side of the disc drive by pulling vertically.
  14. Toshiba SD-K740 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Flip the DVD player so it is resting on its front face (so the back is facing you).
    • Remove the four .320 inch screws holding the motherboard to its casing.
  15. Toshiba SD-K740 Motherboard Replacement: 步骤 15 中的图像 1,2 Toshiba SD-K740 Motherboard Replacement: 步骤 15 中的图像 2,2
    • Push the motherboard forward a few inches to detach it from the casing.
  16. Toshiba SD-K740 Motherboard Replacement: 步骤 16 中的图像 1,2 Toshiba SD-K740 Motherboard Replacement: 步骤 16 中的图像 2,2
    • Lift the motherboard from the rear and pull backward (towards you) to remove it entirely from the case.
结论
Joe Murphy
于01/20/11注册
542 声望
创作了5篇指南
团队
Cal Poly, Team 1-16, Amido Winter 2011 Cal Poly, Team 1-16, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G16
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 13
总计 950
