跳转到主内容
Toshiba SD-K740 Motherboard Fuse Replacement
你所需要的
  1. Toshiba SD-K740 Motherboard Fuse Replacement, Top Panel: 步骤 1 中的图像 1,1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Motherboard Fuse Replacement: 步骤 2 中的图像 1,2 Toshiba SD-K740 Motherboard Fuse Replacement: 步骤 2 中的图像 2,2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Motherboard Fuse Replacement: 步骤 3 中的图像 1,1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Motherboard Fuse Replacement, Motherboard Fuse: 步骤 4 中的图像 1,2 Toshiba SD-K740 Motherboard Fuse Replacement, Motherboard Fuse: 步骤 4 中的图像 2,2
    • Using the plastic opening tool, gently pop the fuse out of its restraining brackets.
结论
另外一个人完成了本指南。
John Lokker
于01/20/11注册
324 声望
创作了3篇指南
团队
Cal Poly, Team 1-16, Amido Winter 2011 Cal Poly, Team 1-16, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G16
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 3,865
