跳转到主内容
Toshiba SD-K740 Inverter Board Replacement
你所需要的
  1. Toshiba SD-K740 Inverter Board Replacement, Top Panel: 步骤 1 中的图像 1,1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Inverter Board Replacement: 步骤 2 中的图像 1,2 Toshiba SD-K740 Inverter Board Replacement: 步骤 2 中的图像 2,2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Inverter Board Replacement: 步骤 3 中的图像 1,1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Inverter Board Replacement, Front Panel: 步骤 4 中的图像 1,1
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Inverter Board Replacement: 步骤 5 中的图像 1,1
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Inverter Board Replacement: 步骤 6 中的图像 1,2 Toshiba SD-K740 Inverter Board Replacement: 步骤 6 中的图像 2,2
    • Grasp the front panel and pull forward to your right to remove it.
  7. Toshiba SD-K740 Inverter Board Replacement, Inverter Board: 步骤 7 中的图像 1,1
    • Remove the black tie holding the two rear ribbon cables together by untwisting it.
  8. Toshiba SD-K740 Inverter Board Replacement: 步骤 8 中的图像 1,2 Toshiba SD-K740 Inverter Board Replacement: 步骤 8 中的图像 2,2
    • Remove the first of two ribbon cables connected to the motherboard by pulling vertically.
  9. Toshiba SD-K740 Inverter Board Replacement: 步骤 9 中的图像 1,2 Toshiba SD-K740 Inverter Board Replacement: 步骤 9 中的图像 2,2
    • Remove the second of two ribbon cables connected to the motherboard by pulling vertically.
  10. Toshiba SD-K740 Inverter Board Replacement: 步骤 10 中的图像 1,1
    • Pull the two cables to the right to disentangle from the disc drive.
    • Do not tug, pull, or force cable, it should slide out with minimal force.
  11. Toshiba SD-K740 Inverter Board Replacement: 步骤 11 中的图像 1,1
    • Pull power cord vertically to detach from the casing.
  12. Toshiba SD-K740 Inverter Board Replacement: 步骤 12 中的图像 1,1
    • Remove the three .303 inch screws attaching the inverter board to the casing using a #0 Phillips screwdriver.
  13. Toshiba SD-K740 Inverter Board Replacement: 步骤 13 中的图像 1,1
    • Push the inverter board forward and to the left to remove from the holding ledges.
  14. Toshiba SD-K740 Inverter Board Replacement: 步骤 14 中的图像 1,2 Toshiba SD-K740 Inverter Board Replacement: 步骤 14 中的图像 2,2
    • Lift the inverter board from the back end and pull toward you to complete removal.
结论
Joe Murphy
于01/20/11注册
542 声望
创作了5篇指南
团队
Cal Poly, Team 1-16, Amido Winter 2011 Cal Poly, Team 1-16, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G16
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 2,125
