跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Toshiba SD-K740 Front Flap Tray Door Replacement
你所需要的
  1. Toshiba SD-K740 Front Flap Tray Door Replacement, Top Panel: 步骤 1 中的图像 1,1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Front Flap Tray Door Replacement: 步骤 2 中的图像 1,2 Toshiba SD-K740 Front Flap Tray Door Replacement: 步骤 2 中的图像 2,2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Front Flap Tray Door Replacement: 步骤 3 中的图像 1,1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Front Flap Tray Door Replacement, Front Panel: 步骤 4 中的图像 1,1
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Front Flap Tray Door Replacement: 步骤 5 中的图像 1,1
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Front Flap Tray Door Replacement: 步骤 6 中的图像 1,2 Toshiba SD-K740 Front Flap Tray Door Replacement: 步骤 6 中的图像 2,2
    • Grasp the front panel and pull forward to your right to remove it.
  7. Toshiba SD-K740 Front Flap Tray Door Replacement, Front Flap Tray Door: 步骤 7 中的图像 1,2 Toshiba SD-K740 Front Flap Tray Door Replacement, Front Flap Tray Door: 步骤 7 中的图像 2,2
    • On back side of front panel very carefully apply pressure to the left hand side of the flap hinge.
    • There is just enough tolerance in the plastic to allow removal, be careful of brittle plastic.
  8. Toshiba SD-K740 Front Flap Tray Door Replacement: 步骤 8 中的图像 1,1
    • Once the peg is free from the left restraint, carefully remove the left part of the flap.
    • Carefully remove the right peg from the restraint.
    • Do not pull away from the front panel because the spring is still attached.
    • Do not force the plastic.
  9. Toshiba SD-K740 Front Flap Tray Door Replacement: 步骤 9 中的图像 1,1
    • Remove the spring from the end of the right peg by pulling the door away from the spring.
    • Do not pull away from the front panel until the spring has been removed from the flap.
结论
John Lokker
于01/20/11注册
324 声望
创作了3篇指南
团队
Cal Poly, Team 1-16, Amido Winter 2011 Cal Poly, Team 1-16, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G16
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,391
