当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Unplug the DVD player before beginning.
Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
Turn the DVD player on its side.
Remove the 7.7 mm screw.
Flip the DVD player onto its other side.
Flip the DVD player over onto its front face.
Remove the back panel by lifting up and pulling it towards yourself.
Flip the DVD player so its top is sitting on your working surface.
Lift and push away the two tabs located in the middle of the player.
The front panel will not detach during this step, so do not force it.
Flip the DVD player on its side.
Lift and slide forward the single tab on the side.
Grasp the front panel and pull forward to your right to remove it.
Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically.
Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically.
Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically.
Remove the four screws holding the disc drive in place using a #0 Phillips screwdriver.
Lift disc drive vertically to remove.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与5其他贡献者
于01/20/11注册
542 声望
创作了5篇指南
徽章: 10
+ 7更多徽章
CPSU-AMIDO-W11S1G16
4 名成员
创作了8篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 2,606
