跳转到主内容
Toshiba Qosmio X775-3DV80 Wifi Chip Replacement
你所需要的
  1. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn your laptop over so the underside is facing up.
  2. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 2 中的图像 1,2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 2 中的图像 2,2
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 3 中的图像 1,1
    • Pull the battery straight out of its slot to remove it.
  4. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Optical Drive: 步骤 4 中的图像 1,1
    • Locate the optical drive retaining screw on the underside of the laptop.
  5. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the optical drive retaining screw.
  6. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 6 中的图像 1,2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 6 中的图像 2,2
    • Using your finger or a spudger, push the optical drive out of its compartment so you can grab it.
    • Pull the optical drive out of its slot in the side of the laptop.
  7. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, RAM: 步骤 7 中的图像 1,1
    • Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
    • It is a captive screw that will remain attached to the service panel.
  8. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 8 中的图像 1,1
    • Using a spudger or plastic opening tool, pry off the service panel.
  9. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 9 中的图像 1,3 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 9 中的图像 2,3 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 9 中的图像 3,3
    • Using your fingers, pull the retaining clips away from the RAM sticks.
    • Pull the RAM sticks out of the slots.
  10. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Keyboard: 步骤 10 中的图像 1,2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Keyboard: 步骤 10 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove all the remaining fourteen screws from the bottom case of the laptop.
    • The service panel should already be removed.
  11. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 11 中的图像 1,2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 11 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the five screws under the service panel.
    • Remove the retaining clip.
  12. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 12 中的图像 1,1
    • Using a spudger, pry the keyboard from the top panel of the laptop.
    • Make sure to pry it off all around.
  13. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 13 中的图像 1,3 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 13 中的图像 2,3 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 13 中的图像 3,3
    • Disconnect the two ribbon cables connecting the keyboard to the laptop.
    • Unplug the connector on the bottom of the laptop.
  14. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Fan: 步骤 14 中的图像 1,1
    • Separate the two halves of the base of the laptop.
  15. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 15 中的图像 1,2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 15 中的图像 2,2
    • Disconnect the two cables.
  16. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 16 中的图像 1,1
    • Remove the palmrest assembly.
  17. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 17 中的图像 1,2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 17 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the four screws securing the fan assembly to the laptop.
  18. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 18 中的图像 1,2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 18 中的图像 2,2
    • Unplug the fan-motherboard connector.
    • Remove the fan unit.
  19. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Wifi Chip: 步骤 19 中的图像 1,1
    • Detach the two coaxial connections from the wifi chip.
  20. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 20 中的图像 1,2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 20 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the two screws from the wifi chip.
  21. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: 步骤 21 中的图像 1,1
    • Remove the wifi chip by pulling it out of the PCIe slot.
结论
Jesse Adam Ory
于03/24/19注册
745 声望
创作了7篇指南
团队
UMass Dartmouth, Team S2-G1, Bailey Spring 2019 UMass Dartmouth, Team S2-G1, Bailey Spring 2019 的会员
UMASSD-BAILEY-S19S2G1
4 名成员
创作了21篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 18
总计 584
