简介
If the computer is booting directly to the BIOS screen and there is enough RAM, then use this guide to replace the Hard Disk Drive.
你所需要的
Use a JIS #0 screwdriver to unscrew the two 4.6 mm screws at the base of the casing.
Pull off the part of the case that's now loose by the indicated tab.
Use the JIS screwdriver head to remove the 3.7mm long JIS #0 screws at the base of the hard drive.
即将完成!
结论
另外一个人完成了本指南。
