跳转到主内容
Toshiba Qosmio X305-Q704 Screen Replacement
你所需要的
  1. Toshiba Qosmio X305-Q704 Screen Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Find an edge of the red strip along the edge the computer and pry it off using a spudger.
  2. Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 2 中的图像 1,2 Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 2 中的图像 2,2
    • Find an edge of the black cover piece around the keyboard and pry it up using the spudger.
  3. Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 3 中的图像 1,2 Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 3 中的图像 2,2
    • Lift the keyboard up and detach the strip connecting the keyboard to the back of the laptop.
  4. Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 4 中的图像 1,3 Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 4 中的图像 2,3 Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 4 中的图像 3,3
    • Remove the keyboard from the Laptop.
  5. Toshiba Qosmio X305-Q704 Screen Replacement, Screen: 步骤 5 中的图像 1,2 Toshiba Qosmio X305-Q704 Screen Replacement, Screen: 步骤 5 中的图像 2,2
    • Unscrew the four 10 mm screws with the Phillips #0 screwdriver.
  6. Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 6 中的图像 1,2 Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 6 中的图像 2,2
    • Insert the iFixit opening tool into the side of the computer that separates the top and bottom of the laptop. Move the tool along the edge of the laptop until the cover can be separated from the device.
    • Do not remove the panel from the device, as you'll need to disconnect cables before the component can be fully removed.
  7. Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 7 中的图像 1,2 Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 7 中的图像 2,2
    • Disconnect all wires connecting the top piece to the bottom.
  8. Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 8 中的图像 1,3 Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 8 中的图像 2,3 Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 8 中的图像 3,3
    • Disconnect all wires connecting the screen to the inside of the computer.
  9. Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 9 中的图像 1,3 Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 9 中的图像 2,3 Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 9 中的图像 3,3
    • Remove the 6 mm screws holding the screen on to the laptop using a Phillips #0 screwdriver.
  10. Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 10 中的图像 1,2 Toshiba Qosmio X305-Q704 Screen Replacement: 步骤 10 中的图像 2,2
    • Remove the screen from the laptop.
结论
另外一个人完成了本指南。
John Borden
于03/08/19注册
220 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G1, Botvin Spring 2019 UMass Dartmouth, Team S1-G1, Botvin Spring 2019 的会员
UMASSD-BOTVIN-S19S1G1
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 509
