当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver.
Locate hidden screw found in the middle of back hardcover.
Found under rubber covering shown in picture.
Remove the single Torx Security screw using a TR7 screwdriver.
Peel off hard cover to expose interior of device.
Find the solid-state drive located below the battery, and next to the RAM.
Unscrew the two 1mm screws located at the top of the solid-state drive with a Phillips #1 screwdriver.
Pull the solid-state drive from its socket
The solid-state drive should automatically pop-up from its housing once the screws are removed.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与4其他贡献者
于02/08/18注册
915 声望
创作了5篇指南
徽章: 11
+ 8更多徽章
UNT-THOMAS-S18S2G3
4 名成员
创作了15篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 1,205
