跳转到主内容
Toshiba Portege Z835-P330 Solid-State Drive Replacement
你所需要的
  1. Toshiba Portege Z835-P330 Solid-State Drive Replacement, Solid-State Drive: 步骤 1 中的图像 1,1
    • Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver.
  2. Toshiba Portege Z835-P330 Solid-State Drive Replacement: 步骤 2 中的图像 1,1
    • Locate hidden screw found in the middle of back hardcover.
    • Found under rubber covering shown in picture.
    • Remove the single Torx Security screw using a TR7 screwdriver.
  3. Toshiba Portege Z835-P330 Solid-State Drive Replacement: 步骤 3 中的图像 1,1
    • Peel off hard cover to expose interior of device.
  4. Toshiba Portege Z835-P330 Solid-State Drive Replacement: 步骤 4 中的图像 1,1
    • Find the solid-state drive located below the battery, and next to the RAM.
    • Unscrew the two 1mm screws located at the top of the solid-state drive with a Phillips #1 screwdriver.
  5. Toshiba Portege Z835-P330 Solid-State Drive Replacement: 步骤 5 中的图像 1,1
    • Pull the solid-state drive from its socket
    • The solid-state drive should automatically pop-up from its housing once the screws are removed.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 1,205
