跳转到主内容
Toshiba Portege Z835-P330 Internal Cooling Fan Replacement
你所需要的
  1. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement, Internal Cooling Fan: 步骤 1 中的图像 1,1
    • Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver.
  2. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: 步骤 2 中的图像 1,1
    • Locate hidden screw found in the middle of back hardcover.
    • Here you will find a proprietary Japanese Screw Head.
    • Remove screw by using tool not provided by IFixit or by using the methods found here.
  3. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: 步骤 3 中的图像 1,1
    • Peel off hard cover to expose interior of device
  4. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: 步骤 4 中的图像 1,1
    • Remove the two 1 mm screws using a Phillips #2 screwdriver.
  5. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: 步骤 5 中的图像 1,1
    • Unplug the internal cooling fan by tugging gently on the wire attatched to the device's motherboard
  6. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: 步骤 6 中的图像 1,1
    • Lift the internal cooling fan to remove the fan from the device
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 549
