跳转到主内容
Toshiba Portege R835-P88 Screen Replacement
你所需要的
  1. Toshiba Portege R835-P88 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Remove the battery by pressing the two buttons inward and pulling the battery out.
  2. Toshiba Portege R835-P88 Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the end caps located on the left and right corners below the screen.
  3. Toshiba Portege R835-P88 Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the square rubber caps on top of the screws
    • Remove the 4 mm screws at the top
    • remove the two 6 mm screws that were under the chrome caps at the bottom.
  4. Toshiba Portege R835-P88 Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the plastic bezel by lightly prying on it. It will pop when it starts to come loose.
  5. Toshiba Portege R835-P88 Screen Replacement: 步骤 5 中的图像 1,2 Toshiba Portege R835-P88 Screen Replacement: 步骤 5 中的图像 2,2
    • Remove tape from around cord attached to the bottom of the screen.
    • Place the screen on top of the keyboard
  6. Toshiba Portege R835-P88 Screen Replacement: 步骤 6 中的图像 1,3 Toshiba Portege R835-P88 Screen Replacement: 步骤 6 中的图像 2,3 Toshiba Portege R835-P88 Screen Replacement: 步骤 6 中的图像 3,3
    • Remove the cord from the screen by cutting the tape where the two fittings meet. After that pull them apart.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 443
