跳转到主内容
Toshiba Portege R835-P88 Optical Drive Replacement
你所需要的
  1. Toshiba Portege R835-P88 Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Start by removing the battery.
  2. Toshiba Portege R835-P88 Optical Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Portege R835-P88 Optical Drive Replacement: 步骤 2 中的图像 2,2
    • Start by removing the back cover by removing the screws, revealing the Optical Drive. Remove the 1 cm screws to remove. Then use the spudger to pry the back off.
  3. Toshiba Portege R835-P88 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • After the cover is removed, remove the screws that hold the Drive. It has 3, 1 cm screws holding it down.
  4. Toshiba Portege R835-P88 Optical Drive Replacement: 步骤 4 中的图像 1,1
    • Take the 2, .5 cm screws out of the drive line. Once this is complete, you have successfully taken out the Optical Drive.
结论
Colt Cates
于01/19/17注册
101 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 663
