跳转到主内容
Toshiba Portege R835-P56X Speaker Replacement
你所需要的
  1. Toshiba Portege R835-P56X Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Turn laptop with the back cover facing up .
    • Make sure the laptop is unplugged and powered off before beginning.
  2. Toshiba Portege R835-P56X Speaker Replacement: 步骤 2 中的图像 1,2 Toshiba Portege R835-P56X Speaker Replacement: 步骤 2 中的图像 2,2
    • Unlock the clips by pulling towards the unlock.
  3. Toshiba Portege R835-P56X Speaker Replacement: 步骤 3 中的图像 1,3 Toshiba Portege R835-P56X Speaker Replacement: 步骤 3 中的图像 2,3 Toshiba Portege R835-P56X Speaker Replacement: 步骤 3 中的图像 3,3
    • Holding the unlock clips push the battery away from the laptop.
  4. Toshiba Portege R835-P56X Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the screws from the back of the laptop
    • you should have removed 18 screws, make sure to keep these in a safe place as you will need them for reassembly.
  5. Toshiba Portege R835-P56X Speaker Replacement: 步骤 5 中的图像 1,2 Toshiba Portege R835-P56X Speaker Replacement: 步骤 5 中的图像 2,2
    • Using the blue prying plastic tool remove the back cover.
  6. Toshiba Portege R835-P56X Speaker Replacement: 步骤 6 中的图像 1,1
    • Remove the screws from the fan and side ports
  7. Toshiba Portege R835-P56X Speaker Replacement: 步骤 7 中的图像 1,3 Toshiba Portege R835-P56X Speaker Replacement: 步骤 7 中的图像 2,3 Toshiba Portege R835-P56X Speaker Replacement: 步骤 7 中的图像 3,3
    • Remove the white and orange cables attached by pulling out the cables
  8. Toshiba Portege R835-P56X Speaker Replacement: 步骤 8 中的图像 1,2 Toshiba Portege R835-P56X Speaker Replacement: 步骤 8 中的图像 2,2
    • locate the speakers
    • Gently lift the motherboard to release the speaker cables
  9. Toshiba Portege R835-P56X Speaker Replacement: 步骤 9 中的图像 1,2 Toshiba Portege R835-P56X Speaker Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using the tweezers, gently remove the tape being used to hold down the speaker cables.
  10. Toshiba Portege R835-P56X Speaker Replacement: 步骤 10 中的图像 1,2 Toshiba Portege R835-P56X Speaker Replacement: 步骤 10 中的图像 2,2
    • Once the cable had been released you have successfully removed the speakers!
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 399
