跳转到主内容
Toshiba Portege R700-S1312 RAM Replacement
你所需要的
  1. Toshiba Portege R700-S1312 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
  2. Toshiba Portege R700-S1312 RAM Replacement: 步骤 2 中的图像 1,1
    • Locate the battery lock button and push it towards the unlock position.
  3. Toshiba Portege R700-S1312 RAM Replacement: 步骤 3 中的图像 1,3 Toshiba Portege R700-S1312 RAM Replacement: 步骤 3 中的图像 2,3 Toshiba Portege R700-S1312 RAM Replacement: 步骤 3 中的图像 3,3
    • Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
  4. Toshiba Portege R700-S1312 RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • Flip the laptop over.
  5. Toshiba Portege R700-S1312 RAM Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips #00 Screwdriver unscrew the 2 40mm screws that are located on the plate covering the RAM.
  6. Toshiba Portege R700-S1312 RAM Replacement: 步骤 6 中的图像 1,1
    • Remove the plate covering the RAM.
  7. Toshiba Portege R700-S1312 RAM Replacement: 步骤 7 中的图像 1,1
    • Pull the sides holding the RAM in place until there is a slight pop.
  8. Toshiba Portege R700-S1312 RAM Replacement: 步骤 8 中的图像 1,1
    • The RAM stick will lift up on its own. Simply remove it.
  9. Toshiba Portege R700-S1312 RAM Replacement: 步骤 9 中的图像 1,1
    • Place new RAM into the RAM drive and gently press until there is a slight pop.
结论
To reassemble your device, simply follow steps 1-3 in reverse order.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 506
