跳转到主内容
Toshiba Portege R700-S1312 Hard Drive Replacement
你所需要的
  1. Toshiba Portege R700-S1312 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
  2. Toshiba Portege R700-S1312 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Locate the battery lock button and push it towards the unlock position.
  3. Toshiba Portege R700-S1312 Hard Drive Replacement: 步骤 3 中的图像 1,3 Toshiba Portege R700-S1312 Hard Drive Replacement: 步骤 3 中的图像 2,3 Toshiba Portege R700-S1312 Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
  4. Toshiba Portege R700-S1312 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Remove the 40 mm screws from the RAM cover using a Phillips #00 Screwdriver.
  5. Toshiba Portege R700-S1312 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Lift and remove the RAM cover to reveal the first of 2 40mm screws holding down the hard drive cover. Remove the screw using a Phillips #00 Screwdriver.
  6. Toshiba Portege R700-S1312 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Remove the second 40mm hard drive cover screw using a Phillips #00 Screwdriver.
  7. Toshiba Portege R700-S1312 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Lift and remove the hard drive cover.
  8. Toshiba Portege R700-S1312 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Connect the drive (in this case a solid state drive) to the laptop using the SATA cable located inside the hard drive placement area.
  9. Toshiba Portege R700-S1312 Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Once the drive is connected, carefully insert the drive into the laptop enclosure.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 28
总计 2,501
