跳转到主内容
Toshiba Portege R700-S1312 Fan Replacement
你所需要的
  1. Toshiba Portege R700-S1312 Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
  2. Toshiba Portege R700-S1312 Fan Replacement: 步骤 2 中的图像 1,1
    • Locate the battery lock button and push it towards the unlock position.
  3. Toshiba Portege R700-S1312 Fan Replacement: 步骤 3 中的图像 1,3 Toshiba Portege R700-S1312 Fan Replacement: 步骤 3 中的图像 2,3 Toshiba Portege R700-S1312 Fan Replacement: 步骤 3 中的图像 3,3
    • Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
  4. Toshiba Portege R700-S1312 Fan Replacement, Fan: 步骤 4 中的图像 1,1
    • Begin by removing 14 70mm screws from the back cover of the laptop using a Phillips #00 Screwdriver. Do not attempt to remove the back cover just yet though.
  5. Toshiba Portege R700-S1312 Fan Replacement: 步骤 5 中的图像 1,1
    • Next, using a Phillips #00 Screwdriver unscrew 2 40mm screws from the RAM cover, and remove the RAM cover.
  6. Toshiba Portege R700-S1312 Fan Replacement: 步骤 6 中的图像 1,1
    • Next, unscrew 2 40mm screws using a Phillips #00 Screwdriver. The back cover will now be able to be removed with greater ease. Note the previously covered 70mm screw illustrated by a red circle on the image.
  7. Toshiba Portege R700-S1312 Fan Replacement: 步骤 7 中的图像 1,2 Toshiba Portege R700-S1312 Fan Replacement: 步骤 7 中的图像 2,2
    • The back cover of the laptop can now be removed by gently lifting its edges with your hands. Avoid abrupt removal of the back cover because it is attached internally. Move the cover to the side and the fan will now be visible.
  8. Toshiba Portege R700-S1312 Fan Replacement: 步骤 8 中的图像 1,2 Toshiba Portege R700-S1312 Fan Replacement: 步骤 8 中的图像 2,2
    • Remove the two 50mm screws holding down the fan using a Phillips #00 screwdriver.
  9. Toshiba Portege R700-S1312 Fan Replacement: 步骤 9 中的图像 1,1
    • Disconnect the fan's power cables from the motherboard by gently pulling the white connector towards the fan and away from the motherboard.
  10. Toshiba Portege R700-S1312 Fan Replacement: 步骤 10 中的图像 1,1
    • You can now safely remove the fan completely and replace it with your replacement fan.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,539
