跳转到主内容
Toshiba Portege R500 Wi-FI Card Replacement
你所需要的
  1. Toshiba Portege R500 Wi-FI Card Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Portege R500 Wi-FI Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
  2. Toshiba Portege R500 Wi-FI Card Replacement, Wi-FI Card: 步骤 2 中的图像 1,1
    • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  3. Toshiba Portege R500 Wi-FI Card Replacement: 步骤 3 中的图像 1,1
    • Pull up on the back casing and remove it, revealing the Wi-Fi card.
  4. Toshiba Portege R500 Wi-FI Card Replacement: 步骤 4 中的图像 1,2 Toshiba Portege R500 Wi-FI Card Replacement: 步骤 4 中的图像 2,2
    • Unscrew the two 3.5 mm screws from the Wi-Fi card with the Phillips 00 screwdriver.
    • Pull the Wi-Fi card towards the battery slot to release it.
  5. Toshiba Portege R500 Wi-FI Card Replacement: 步骤 5 中的图像 1,1
    • Remove the three wires from the Wi-Fi card by pulling them straight up and off.
    • The Wi-Fi card should now be free of the laptop.
    • When removing the wires be sure to remember which wire came from which port, consider marking them so that you can remember.
结论
JRJones
于04/19/13注册
169 声望
创作了5篇指南
团队
Cal Poly, Team 2-19, Maness Spring 2013 Cal Poly, Team 2-19, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G19
3 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,278
