跳转到主内容
Toshiba Portege R500 CD Drive Replacement
你所需要的
  1. Toshiba Portege R500 CD Drive Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Portege R500 CD Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
  2. Toshiba Portege R500 CD Drive Replacement, CD Drive: 步骤 2 中的图像 1,1
    • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  3. Toshiba Portege R500 CD Drive Replacement: 步骤 3 中的图像 1,2 Toshiba Portege R500 CD Drive Replacement: 步骤 3 中的图像 2,2
    • Pull up on the back casing and remove it, revealing the CD drive.
  4. Toshiba Portege R500 CD Drive Replacement: 步骤 4 中的图像 1,1
    • Flip the CD Drive over carefully, lifting the right side and turning the drive in order to reveal the attachment.
  5. Toshiba Portege R500 CD Drive Replacement: 步骤 5 中的图像 1,2 Toshiba Portege R500 CD Drive Replacement: 步骤 5 中的图像 2,2
    • Rotate the laptop ninety degrees so the screws and connection are visible.
    • Remove the two 4 mm screws with the Phillips 00 screwdriver.
    • Pull the ribbon cable away from the laptop to release the CD drive from the computer.
    • A small metal divider may fall when you remove the ribbon cable. It needs to be reattached in between the ribbon cable and the drive when the new drive is put in.
结论
另外一个人完成了本指南。
JRJones
于04/19/13注册
169 声望
创作了5篇指南
团队
Cal Poly, Team 2-19, Maness Spring 2013 Cal Poly, Team 2-19, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G19
3 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,858
