跳转到主内容
Toshiba Portege M400 Motherboard Replacement
你所需要的
  1. Toshiba Portege M400 Motherboard  Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Using the plastic opening tool, remove the plastic hinge cover on the back of the laptop. Use caution not to damage this plastic cover.
  2. Toshiba Portege M400 Motherboard  Replacement: 步骤 2 中的图像 1,1
    • Using the plastic opening tool, remove the plastic cover directly above the keyboard. Make sure to start from the corners of the plastic cover.
  3. Toshiba Portege M400 Motherboard  Replacement: 步骤 3 中的图像 1,1
    • Using the #1 Phillips head screwdriver, remove the two 3.8mm screws.
  4. Toshiba Portege M400 Motherboard  Replacement: 步骤 4 中的图像 1,1
    • Remove the keyboard, make sure you gently remove any ribbon cables holding it to the rest of the computer. Bending or crimping a ribbon cable can break the device.
  5. Toshiba Portege M400 Motherboard  Replacement: 步骤 5 中的图像 1,2 Toshiba Portege M400 Motherboard  Replacement: 步骤 5 中的图像 2,2
    • Use a small phillips screwdriver to remove both metal shields as depicted.
  6. Toshiba Portege M400 Motherboard  Replacement: 步骤 6 中的图像 1,2 Toshiba Portege M400 Motherboard  Replacement: 步骤 6 中的图像 2,2
    • After removing the second metal covering you will remove the RAM compartment.
    • Simply pull apart the metal fasteners on the side; the RAM should pop out for removal.
  7. Toshiba Portege M400 Motherboard  Replacement: 步骤 7 中的图像 1,3 Toshiba Portege M400 Motherboard  Replacement: 步骤 7 中的图像 2,3 Toshiba Portege M400 Motherboard  Replacement: 步骤 7 中的图像 3,3
    • Disconnect the wire from the exposed wireless card.
    • Pry open the top of the laptop and gently remove and disconnect the wires as shown.
  8. Toshiba Portege M400 Motherboard  Replacement: 步骤 8 中的图像 1,2 Toshiba Portege M400 Motherboard  Replacement: 步骤 8 中的图像 2,2
    • Remove the screws attaching the motherboard to the plastic housing.
    • Lift off the motherboard. Once it is free of screws and you're done!
结论
另外一个人完成了本指南。
Dustin
于03/12/14注册
1,213 声望
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 1,256
