跳转到主内容
Toshiba Portege M400 Keyboard Replacement
你所需要的
  1. Toshiba Portege M400 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the front face plate with a plastic opening tool.
    • Unscrew and remove the two 3.8mm screws labeled B3 with the #1 Phillips screwdriver.
  2. Toshiba Portege M400 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Lift the keyboard toward you starting from the edge closest to the screen.
    • This ribbon still connects the taptor to the keyboard.
    • Gently place the keyboard on top of the track pad with the keys upside down.
  3. Toshiba Portege M400 Keyboard Replacement: 步骤 3 中的图像 1,3 Toshiba Portege M400 Keyboard Replacement: 步骤 3 中的图像 2,3 Toshiba Portege M400 Keyboard Replacement: 步骤 3 中的图像 3,3
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Remove the screw on the metal plate that keeps the ribbon from sliding out.
    • Gently remove the metal plate and set it aside.
  4. Toshiba Portege M400 Keyboard Replacement: 步骤 4 中的图像 1,2 Toshiba Portege M400 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Dislodge the white ribbon connector from the two clips holding it in place using the plastic opening tools.
    • Pull out the white ribbon connector with your fingers.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 4-17, Maness Spring 2013 Cal Poly, Team 4-17, Maness Spring 2013 的会员
CPSU-MANESS-S13S4G17
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,022
