1. Remove the two circled screws and place them in a safe location.
    • Remove the two circled screws and place them in a safe location.
  2. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Gently lift the plastic plate as shown in the image and slide it out from it's position.
    • Gently lift the plastic plate as shown in the image and slide it out from it's position.
  4. Gently lift the plastic tab and carefully remove the hard drive from its connective port.
    • Gently lift the plastic tab and carefully remove the hard drive from its connective port.
    • You are done!
结论
Lucas
于2014年03月26日注册
101 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 11
总计 548
