跳转到主内容
Toshiba Portege M300 Wireless Card Replacement
你所需要的
  1. Toshiba Portege M300 Wireless Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 Wireless Card Replacement: 步骤 2 中的图像 1,2 Toshiba Portege M300 Wireless Card Replacement: 步骤 2 中的图像 2,2
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 Wireless Card Replacement: 步骤 3 中的图像 1,2 Toshiba Portege M300 Wireless Card Replacement: 步骤 3 中的图像 2,2
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 Wireless Card Replacement, Wireless Card: 步骤 4 中的图像 1,3 Toshiba Portege M300 Wireless Card Replacement, Wireless Card: 步骤 4 中的图像 2,3 Toshiba Portege M300 Wireless Card Replacement, Wireless Card: 步骤 4 中的图像 3,3
    • Turn the computer onto the back.
    • Remove the Phillips #0 screw that secures the cover to the rest of the device.
    • One 5.1 mm coarse thread screw.
    • Pull the cover forward to release it.
  5. Toshiba Portege M300 Wireless Card Replacement: 步骤 5 中的图像 1,3 Toshiba Portege M300 Wireless Card Replacement: 步骤 5 中的图像 2,3 Toshiba Portege M300 Wireless Card Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the two screws on opposite corners of the wireless card.
    • Two 4.0 mm coarse thread screws.
    • Use a plastic opening tool to gently lift the wireless card out while leaving the wire connected.
  6. Toshiba Portege M300 Wireless Card Replacement: 步骤 6 中的图像 1,2 Toshiba Portege M300 Wireless Card Replacement: 步骤 6 中的图像 2,2
    • Hold the edges of the wireless card and carefully disconnect the black 3 pin connector.
结论
Alison Wendt
于04/18/13注册
135 声望
创作了6篇指南
团队
Cal Poly, Team 21-51, Johann Spring 2013 Cal Poly, Team 21-51, Johann Spring 2013 的会员
CPSU-JOHANN-S13S21G51
3 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 848
