当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Locate the two screw covers and screws that can be found underneath the screen of the laptop.
Once located remove the screw covers and screws from underneath the screen by using the correct sized Phillips head screwdriver.
The screen should readily detach from the laptops body.
这个步骤还没有翻译 帮忙翻译一下
Locate the wires that connect the screen to the laptops body. (They are located at the bottom left side of the screen.)
Lift up the black protective cover that the wires lie under.
With one hand holding the black cover up, with free hand carefully pull away the wires, removing them from the laptop’s body.
2等其他人完成本指南。
