当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove all eight plastic circular covers on the plastic screen bezel.
Only seven of these plastic covers will contain screws underneath.
Unscrew all seven screws with a Phillips head #000 screwdriver.
Use a plastic opening tool to separate the screen bezel from the rest of the case.
Pull at the top edge of the LCD to separate it from the top part of the case.
Only separate the casing and the LCD by an inch—there are still wires connecting them.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
